Date/Time: Sat, 11 May 2024 16:44:24 +0000
Setting the Software dificulties
View Count: 500
[2020-07-30 17:29:26] |
User481346 - Posts: 1 |
Hi, I open an accout with Sierra Chart! I'm trying to prepare the trying settings for the software to work. 1st Question - Can I use the software for Penny Stocks from Nasdaq? How can I make them to be available. 2nd Question - It doesn't appear the option 'Connect to Data Fee' in the File Menu. I've configured the step 7 as you said and on the 8 the option 'Connect to Data Fee' is disabled. How can I work this out? |
[2020-07-30 18:42:25] |
1. Yes use the Sierra Chart Historical Data Service: Sierra Chart Historical Data Service You can find the symbols here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=6#OTHER%20OTC These are the standard US stock symbols. 2. The command is definitely there but if it is disabled it means Sierra Chart is already connected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-30 18:43:10
