Date/Time: Sun, 28 Apr 2024 12:34:14 +0000
Keyboard Shortcuts for Hide Values Scale & Hide Time Scale
View Count: 1573
[2020-07-30 13:10:55] |
User247273 - Posts: 37 |
Any chance you might add Hide Values Scale & Hide Time Scale to the Customize Keyboard Shortcuts options? In a case where those are set to hidden, being able to toggle them on/off to make quick adjustments to the chart scale would be WAY more efficient with a shortcut than the current method which requires 9 steps. 1. Open Chart Settings 2. Click Advanced Settings tab 3. Check/Uncheck Hide Values Scale and/or Hide Time Scale 4. Save Settings 5. Make the desired adjustments to the chart scale 6. Open Chart Settings 7. Click Advanced Settings tab 8. Revert checkboxes to original settings for Hide Values Scale and/or Hide Time Scale 9. Save Settings |
[2020-11-13 16:52:47] |
whats1thingnow - Posts: 407 |
other threads that are asking for the same thing: - Shortcut Feature request from year 2014 - Keyboard shortcuts another from year 2014 - Can you put "Hide value scales" under the available list of Customize Chart Shortcut M from year 2015 pleaes please please add keyboard shortcuts (shortcut, hotkey, hotkeys) to: Hide/Show Values Scale Hide/Show Time Scale thank you SC support you are awesome Date Time Of Last Edit: 2020-11-13 17:12:29
[2021-04-07 18:06:36] |
just following up on this. thanks |
[2021-04-08 15:38:46] |
User311344 - Posts: 136 |
+1
[2021-04-08 16:36:24] |
Botan626 - Posts: 294 |
+1
[2022-09-09 09:15:19] |
Sudhirc - Posts: 50 |
+1
[2023-06-26 08:53:25] |
User355493 - Posts: 23 |
I am also looking for such a function. Is there a solution in the meantime for this ?
[2023-07-11 07:27:07] |
Sierra_Chart Engineering - Posts: 14111 |
Update to the latest version. Keyboard Shortcuts and Control Bar buttons have been added for these.
[2023-12-06 00:39:21] |
User953554 - Posts: 7 |
hi I have the latest version but I just can't find the show/hide timeScale/valuesScale in the customise Keyboard Shortcuts dropdown menu. I have been through it multiple times but I can't see it. can someone give me a step by step please?? thanks |
[2023-12-06 15:47:19] |
It is only available in the Control Bar options, not as a Keyboard Shortcut. Under the Control Bar selections, they are within the section for "Chart - General". They are just below "Logarithmic Scaling" and above "Bid Ask Line".
[2023-12-07 11:12:43] |
Ok thanks for the clarification. Is there a keyboard shortcut or an assignable control bar button function to grow/shrink the vertical scale of the chart? I only need the price scale on all but one chart for re-sizing quickly when changing symbols etc. Is a keyboard shortcut for either of these functions possible as a new feature? When working from a laptop hide/unhide price scale is a constant action due to the small screen. Thanks |
[2023-12-07 16:35:47] |
There is not an option for changing the size of the vertical scale. These have been noted as Feature Requests, we just can't say when we would get to any particular request. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
