Date/Time: Sat, 11 May 2024 23:23:14 +0000
Hi, can you please add 0.5 to support and resistance for PIVOT POINTS STUDIES
View Count: 599
[2020-07-29 02:26:33] |
User346587 - Posts: 7 |
Hi, it's all in the title. Thank you |
Screenshot_996.png / V - Attached On 2020-07-29 02:25:15 UTC - Size: 39.97 KB - 190 views |
[2020-07-29 05:23:53] |
This exists already. These would be the R.5 and S.5 Subgraphs.
[2020-07-29 19:57:57] |
Hi, so S5 is supposed to give me the middle between PP and S1? Because right now it's not doing that. We have the option of 1.5 for example but not 0.5 (value between PP and 1.0) Thank you |
[2020-07-29 22:06:20] |
Note, that it is S.5 and R.5, not S5 (or R5). But not all the Pivot Point options have the .5 defined. Therefore, depending on which one you are using, it may not draw anything when you select the subgraph to draw. Let us know which Pivot Point Formula Type you are using that does not appear to have the .5 lines and we will see if it is possible to add .5 Support and Resistance lines. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
