Date/Time: Sat, 18 May 2024 23:41:46 +0000
probleme de liaison avec rhitmic
View Count: 482
[2020-07-28 21:46:56] |
User893796 - Posts: 1 |
message d'erreur pour la connexion avec les data rhitmic !
[2020-07-29 18:25:38] |
Refer to the information here: Regarding Rithmic (Our Final Post on this Subject) If you need the files to be able to connect to Rithmic, you will find them here: Rithmic Bridge Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
