Date/Time: Sat, 11 May 2024 13:49:35 +0000
Range chart y-axis (price) font size
View Count: 895
[2020-07-28 17:40:28] |
User325501 - Posts: 2 |
I went to Global Settings->Graphics Settings - Global, selected the Fonts tab and highlighted Chart Text - Segoe UI and changed font size from default of 9 to 12, but that only changes some of my charts. For example my heatmap and footprint charts with ES shows the larger font size, but my 10 and 5 tick range chart still shows a tiny font on the y-axis (the price axis). What went wrong? Thanks!
fontsize.PNG / V - Attached On 2020-07-28 17:39:53 UTC - Size: 716.94 KB - 237 views |
[2020-07-29 05:12:35] |
The charts that did not change are using Chart specific Graphics Settings. Refer to the information here: Graphics Settings: Using Different Color and Graphics Settings for Specific Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
