Date/Time: Sun, 12 May 2024 17:52:47 +0000
order plancing
View Count: 523
[2020-07-28 13:11:24] |
User695019 - Posts: 32 |
hello iam new and when i place order and close it wither in profit or loss and then i go check my balance i find it still the same no loss no profit nothing happened please tell me where the problem is. thank you |
[2020-07-29 05:11:31] |
We do not know. Sierra Chart has no control over Account Balance data.
[2020-07-29 19:51:29] |
i have another problem with my chart as you see in the picture i cant even see the TPO letters, i dont know where to click so i can see it clearly. please help. |
[2020-07-30 09:40:18] |
Refer to: Time Price Opportunity (TPO) Profile Charts: Scaling the TPO Profile Chart You have to expand the axes to where you can see what you want. There is a tradeoff between being able to read the letters and how much of the TPO Profile you will be able to see. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
