Date/Time: Fri, 10 May 2024 11:24:20 +0000
Trade Window Size
View Count: 1030
[2020-07-28 01:27:21] |
User425645 - Posts: 113 |
Hello. Is it possible to change the trade window size? as you can see from the post below it is a little big. Thanks for your time. |
[2020-07-29 18:02:19] |
is this a feature or something im able to do ?
[2020-07-30 00:09:12] |
Refer to: Graphics Settings: Adjusting Size of Dialog Windows Also please know that all of the dialog windows in Sierra Chart are in the process of being replaced with new ones which will be resizable. However, this is not going to be complete until about a year from now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-30 04:41:57] |
Also, there is this one option that is described in the 3rd paragraph of this section: Basic Trading and the Trade Window: Trade Window Controls Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-30 04:42:32
