Date/Time: Mon, 20 May 2024 03:53:11 +0000
large volume trade and number bars data dont match!
View Count: 476
[2020-07-27 13:50:47] |
User432142 - Posts: 44 |
NQU20_FUT_CME chart setting= combine trades into original summary trade large volume trade indicator *draw mode= based on total volume *volume threshold= 5 when l have above setting, number bars shows data different than large volume indicator number bars indicator show 12 contracts buy side but large volume shows 16 contracts. l couldn't understand behind of the logic why LVT indicator shows data bigger then number bars pls check attached screenshots one of them is time and sales, the other one graph thank you |
number bars.jpg / V - Attached On 2020-07-27 13:47:50 UTC - Size: 188.21 KB - 199 views time and sales.jpg / V - Attached On 2020-07-27 13:47:59 UTC - Size: 429.09 KB - 205 views |
[2020-07-27 15:27:22] |
User907968 - Posts: 804 |
Is it because you are using 'total volume' and you have a 10 lot buy and a 6 lot sell @ 10551.50?
[2020-07-27 15:53:47] |
yes it might be correct. it shows that sum of all trade of both sides at same price which bigger than volume threshold but when l set draw mode as based on max volume, it shows highest volume my question is how l can set indicator then it shows that sum of all trade of only one side at same price which bigger than volume threshold thank you Date Time Of Last Edit: 2020-07-28 04:41:29
