Date/Time: Fri, 10 May 2024 00:08:30 +0000
Numbers Bars - Bold Last Trade Price and Bid/Ask Bold Threshold?
View Count: 696
[2020-07-26 22:59:04] |
User128888 - Posts: 30 |
I'm trying to enable the Bold Last Trade Price and Bid / Ask Bold Threshold and I can't seem to get it to work. What should it look like? Nothing gets bolded for me. I've tried it with a brand new chart too. Thanks.
[2020-07-29 05:22:30] |
Are you using the OpenGL option in Sierra Chart?
BoldLastTradePrice.png / V - Attached On 2020-07-27 15:22:10 UTC - Size: 9.38 KB - 213 views |
[2020-07-29 11:26:55] |
Ah, yes I have OpenGL option and this explained it. With OpenGL off, I do see the bolding. Thank you.
[2020-07-30 18:28:21] |
OpenGL does not support bold or underlining text.
