Date/Time: Mon, 29 Apr 2024 15:54:56 +0000
data issue
View Count: 2127
[2013-04-18 03:56:54] |
We have not had a chance yet to test this.
[2013-04-18 18:23:16] |
We have run a test and the chart looks good for us: http://www.sierrachart.com/image.php?l=136630453947.png Follow each and every step-by-step instruction here: http://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#ContinuousFuturesContract We have established clear procedures for this, and you should not have any trouble as long as you follow through each step. Be sure to follow step #11. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-18 18:25:46
