Date/Time: Mon, 06 May 2024 04:51:26 +0000
[User Discussion] - Feature Request: Adjusting width of Open Position/Order Lines on Chart
View Count: 597
[2020-07-22 16:40:54] |
BlueVein - Posts: 34 |
Hello, this is a request to allow users to adjust the width of the open order lines on your chart when chart trading. Specifically trying to set it up so my avg fill and working stops/targets are not covering price action and just to the far right of the chart. Let me know if you would consider this. Thank you. |
[2022-06-15 18:14:58] |
j4ytr4der_ - Posts: 918 |
I would very much like to adjust the width of these lines as well, in particular because I use my Trade Windows detached so as to not have the dead space below them, that would otherwise be there. But I position them in the upper left corner of the chart, which means that the informational component of the lines, can wind up underneath the Trade Window and not visible. If I could just narrow them by a couple hundred pixels, it would be perfect. Would love to see this considered.
[2022-06-15 18:17:54] |
Strike that, this is already implemented just not obvious where to find it. Chart Trading and the Chart DOM: Change Location of Orders and Position Lines on Chart |
