Date/Time: Sat, 18 May 2024 16:33:09 +0000
[Programming Help] - Display indicator in future
View Count: 606
[2020-07-21 14:02:53] |
gfx2trade - Posts: 48 |
Hello SC Team, Trying to display on chart SSB indicator. I us both the native SC study (Green) and the one created with the below code (blue). I don't understand why the blue line does not overlap the green in the future. Thks for helping SCSFExport scsf_gfxSSB(SCStudyInterfaceRef sc)
{ // Graphs & Input SCSubgraphRef Subgraph_H = sc.Subgraph[0]; SCSubgraphRef Subgraph_L = sc.Subgraph[1]; SCSubgraphRef Subgraph_M = sc.Subgraph[2]; // Working //float myHigh = 0; //float myLow = 0; //float myMid = 0; SCFloatArray myHigh; SCFloatArray myLow; SCFloatArray myMid; // Section 1 - Set the configuration variables and defaults if (sc.SetDefaults) { sc.GraphName = "TEST SSB; sc.StudyDescription = "This is the gfx SSB indicator"; sc.DrawZeros = false; sc.GraphRegion = 0; sc.ValueFormat = sc.BaseGraphValueFormat; Subgraph_M.Name = "RBM"; Subgraph_M.DrawStyle = DRAWSTYLE_LINE; Subgraph_M.LineWidth = 2; //Width of arrow Subgraph_M.PrimaryColor = RGB (0, 0, 255); // Green sc.AutoLoop = 1; sc.AlertOnlyOncePerBar = true; return; } // ************************************ // Section 2 - Do data processing here // ************************************ int index = sc.Index; int OutputIndex = index + 26; int CalculationStartIndex = max(0, sc.UpdateStartIndex - 2); sc.EarliestUpdateSubgraphDataArrayIndex = CalculationStartIndex; sc.Highest(sc.BaseDataIn[SC_HIGH], Subgraph_H, 52); sc.Lowest(sc.BaseDataIn[SC_LOW], Subgraph_L, 52); myHigh[index] = Subgraph_H[index]; myLow[index] = Subgraph_L[index]; myMid[index] = (myHigh[index] + myLow[index]) / 2 ; Subgraph_M[OutputIndex] = myMid[index]; } Date Time Of Last Edit: 2020-07-21 14:03:19
Capture.JPG / V - Attached On 2020-07-21 14:01:49 UTC - Size: 32.58 KB - 266 views |
[2020-07-21 14:39:25] |
User907968 - Posts: 804 |
Maybe this - ACSIL Interface Members - sc.Subgraph Array: sc.Subgraph[].ExtendedArrayElementsToGraph |
[2020-07-21 19:08:23] |
Indeed
