Date/Time: Sat, 18 May 2024 15:41:02 +0000
Stop limit orders...!
View Count: 554
[2020-07-20 18:57:20] |
User656746 - Posts: 10 |
How can I place a stop limit orders to enter a market where stop and limit are the same(Diff=0), and use a regular stop market order as protective stop when things go wrong? I found under the "Set" tab "Stop Limit Order Limit Offset" 2 boxes. Primary Orders where I assume I put a zero, so that "trigger price and limit are the same, but what do I put in for Attached Orders to have a regular stop market stoploss? -1?? |
[2020-07-20 20:19:10] |
ondafringe - Posts: 248 |
If you're trading CME or ICE products, those exchanges will automatically add a Stop-limit order to your position "X" points out from your regular Stop. The "X" amount is determined by the product you are trading. For ES/MES, the "X" is equal to 3 points.
[2020-07-21 09:24:50] |
Follow the instructions here regarding Stop-Limit orders: Order Types: Stop-Limit Yes this is correct: Primary Orders where I assume I put a zero, so that "trigger price and limit are the same
The corresponding setting is not relevant for a Stop market order type: what do I put in for Attached Orders to have a regular stop market stoploss? -1?? So it does not matter.
[2020-07-21 16:12:43] |
Thank yo so much!
