Date/Time: Sat, 04 May 2024 15:54:59 +0000
Total Daily Volume Traded
View Count: 1768
[2013-04-17 01:49:48] |
tr726 - Posts: 30 |
Were can i find a total daily volume traded on the charts or dom?
[2013-04-17 01:57:16] |
You can look at Window >> Current Quote Window or add the Daily Volume field to the chart header in Global Settings >> Customize Chart Header.
