Date/Time: Sat, 18 May 2024 05:24:30 +0000
[User Discussion] - Alert run program PowerShell script
View Count: 1066
[2020-07-19 08:26:17] |
User672883 - Posts: 4 |
Is it possible to run a PowerShell script (instead of a program) when an alert is triggered? I am able to run the PowerShell script successfully from both Command Prompt and Windows Powershell. However, when I specify the file path to the PowerShell script in "General Settings -> Alerts/General 3 -> Run Program When This Alert Triggered" I get a variety of different error messages depending on the various file paths I try (in an attempt to make it work). |
[2020-07-19 09:21:19] |
Have a look at this article: https://stackoverflow.com/questions/25919451/use-createprocess-to-run-a-batch-file Sierra Chart will use CreateProcess. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
