Date/Time: Sun, 19 May 2024 18:37:19 +0000
Edit>>Delete All Data And Download in source instance of SC
View Count: 1075
[2014-01-30 11:54:24] |
User16114 - Posts: 153 |
1. Does "Edit>>Delete All Data And Download" in a source instance (IQFeed) chart refresh data in all intraday time based charts in the source instance and the destination instance (AMP/TTNet) of SC, for the same symbol? 2. When "Intraday Data Storage Time Unit" is set to "1 Tick" in the source instance (IQFeed) does "Edit>>Delete All Data And Download" in a source instance (IQFeed) intraday chart refresh data in all "Bar Period" (Days-Mins..., Volume Per Bar, Number of Trades Per Bar... etc.) types, in charts in the source instance and the destination instance (AMP/TTNet) of SC, for the same symbol? |
[2014-01-30 17:58:08] |
1. Yes. But after the download is complete, you may need to reload the charts for that symbol in the destination instances by going to those charts and selecting Chart >> Reload and Recalculate . This is something that will be resolved later on but we have not gotten to it yet. 2. Yes. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
