Date/Time: Mon, 20 May 2024 00:55:01 +0000
Rim file download
View Count: 854
[2020-07-15 17:38:21] |
Moogroo - Posts: 4 |
Hello, I am trying to download the the files necessary to connect to my rithmic data feed, which you kindly provided in this thread: I cannot get sierra charts to work on my new computer however the link provided in the thread (https://www.sierrachart.com/Download.php?Folder=SupportBoard&download=39787) comes up with an "access denied" error on clicking. would it be possible to have the zip file necessary to copy into the Rim folder? I understand rithmic will not be supported going forward and I do not plan to use it for much longer (I'll be moving across to your Denali feed) - I just have some loose ends to tie up first Thank you for your help, and again for a very good robust platform |
[2020-07-15 20:30:01] |
You can get the files from here: Rithmic Bridge Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
