Date/Time: Thu, 16 May 2024 19:40:30 +0000
Sub Instance Not Connected
View Count: 491
[2020-07-15 16:30:20] |
User495307 - Posts: 1 |
I don't have data feed to my sub instances. In the message log it says "Current service package does not support this function" I just checked my account detail and it's package 5. I also updated to the current version to 2135 64-bit. Was there any change on how to run DTC- Sub Instance ? |
[2020-07-15 19:40:43] |
Your sub instances are still on version 1997. You need to exit from them, and then run them again.
