Date/Time: Fri, 03 May 2024 05:37:37 +0000
[User Discussion] - Anchored VWAP
View Count: 4517
[2020-07-15 11:09:00] |
jruz - Posts: 1 |
Hi, I would like know if it's possible to draw a VWAP from a place selected by me using the cursor. Similar to what TradingView or TrendSpider do: https://www.tradingview.com/blog/en/anchored-vwap-is-on-tradingview-18573/ Thanks |
[2020-07-21 08:47:40] |
User745789 - Posts: 173 |
You can create excellent click and draw anchored vwaps by using the "Draw Volume Profile" tool with a custom tool config that only shows the vwap from the volume profile. It works perfectly. You can then click and drag the anchor point AND the end point, aka, you can stipulate the end of an anchored vwap. Now, PLEASE LOBBY SIERRA CHART so that they modify the code to allow the vwap used in the Volume by Price Study to be calculate using either the High or Lows and input data (like is possible for the normal vwap study). This code can not be custom modified, people have tried. |
[2020-11-26 13:06:48] |
Ackin - Posts: 1865 |
User contributed studies Menu/Analysis/Studies - Add Custom study -> User Contributed Studies ... study ECI Anchor VWAP Date Time Of Last Edit: 2020-11-26 13:29:35
[2021-03-17 15:03:49] |
User311677 - Posts: 16 |
User745789 It would be great if we had more calculations methods for VWAP inside Draw Volume Profile Tool (just like normal VWAP study does)
[2021-03-17 23:11:06] |
User234172 - Posts: 44 |
It has been asked... Drawn Volume by Price Study: use H or L for vwap calculation |
[2021-03-18 00:34:42] |
Let's hope they do it.Today I have been trying to custom make VWAP with percentage and offset calculation that can be Anchored by mouse. Or trying to add offset to ECIVWAPAnchorV1.5, but it is just too difficult for me. |
