Date/Time: Thu, 16 May 2024 18:30:46 +0000
Update chart time zone from Global Symbol Settings
View Count: 532
[2020-07-15 06:26:33] |
User672883 - Posts: 4 |
For an intraday chart in Global Symbol Settings for the specific symbol I have set a custom time zone, session start/end times, and have selected 'Use Custom Symbol Setting Values' and 'Apply Intraday Session Times to Intraday Chart'. In Chart Settings > Advanced Settings I have also selected 'Apply Intraday Session Times To Intraday Chart'. When clicking in Chart Settings on 'Apply Global Symbol Settings' the charts Time Zone does not update to the custom time zone I set in Global Symbol Settings. It does update the session start/end times. Shouldn't it update the Time Zone as well? Thanks. |
[2020-07-15 19:51:35] |
The Time Zone setting in the Symbol Settings is only to define the Session Times time zone, not the chart time zone. Refer to the information for the Time Zone in the Symbol Settings in this section: Global Symbol Settings: Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
