Date/Time: Thu, 16 May 2024 15:48:58 +0000
Chart->Replay Chart Inconsistent Results Using Same Inputs
View Count: 579
[2020-07-14 22:01:53] |
PeaceFrog - Posts: 102 |
I've been using "Chart->Replay Chart" to back-test a strategy and have found that the results drastically differ each time I play through the entire time period (I haven't changed anything in the formula columns/ strategy between playbacks), even when I change the "Replay Mode" to "Accurate Trading System Back Test Mode" and I don't understand why? Thank you for taking the time to respond. |
[2020-07-15 19:57:35] |
Refer to: Auto Trade System Back Testing: Consistency Between Back Tests We are not sure this is relevant, but update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-08-10 09:11:37] |
Hello, Thank you very much for responding to my question. I'm happy to say that doing the Update, disconnecting from the live feed and reducing the number of rows has enabled consistent results. Thank you for your time. It's very much appreciated. |
