Date/Time: Thu, 16 May 2024 15:55:44 +0000
Wrong prices Mini SP
View Count: 696
[2020-07-14 19:53:04] |
User141430 - Posts: 1 |
I have this problem with almost all the chartbooks I load, it shows me the prices of the Mini SP with several zeros at the end and with inconsistent quantities . I tried to edit the global setting of the symbol, and the price display format and nothing worked. What could be happening?
Screenshot_1.png / V - Attached On 2020-07-14 19:52:09 UTC - Size: 84.85 KB - 218 views |
[2020-07-15 05:14:34] |
Disable this setting: Global Symbol Settings: Use Custom Symbol Settings Values (Global Settings >> Symbol Settings) And then open a new chart for that symbol. We cannot help with that existing chart. We do not know what you have done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
