Date/Time: Sun, 05 May 2024 16:16:59 +0000
Notice: US Equities Feed Issue as of 14:00 US Eastern Time 2020-07-14
View Count: 929
[2020-07-14 18:53:09] |
The US equities data feed we receive from Barchart over the Open Feed protocol has an issue where the amount amount of trade data being delivered, is dramatically less. This can be observed by looking at the volume for this stock symbol: http://www.sierrachart.com/image.php?Image=1594752563895.png Barchart has been notified and we are waiting for a resolution and explanation. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-14 19:05:49] |
The problem is resolved. Barchart has reset/restarted their Open Feed: OpenFeed | Received heartbeat | 2020-07-14 14:53:41.877 OpenFeed | Incremental Socket socket sequence number wrapped. SeqNum=1 LastSeqNum=48770378 | 2020-07-14 15:00:43.101 OpenFeed | Incremental reset detected. Signaling to end packet processing thread. | 2020-07-14 15:00:43.102 OpenFeed | Packet Processing thread complete. Thread ID: 4320 | 2020-07-14 15:00:43.102 OpenFeed | Processing thread has ended. Calling OnConnectionLost | 2020-07-14 15:00:43.851 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-14 19:06:13
