Date/Time: Thu, 16 May 2024 17:50:29 +0000
Incorrect P/L Display
View Count: 546
[2020-07-14 09:19:34] |
evagoras hadjimereos - Posts: 7 |
Hi, The P/L display on my live account is not displayed correctly. For instance, the P/L is calculated by using a tick size of 6.26 than 6.25 on the Euro FX product. I have double checked the Symbol Settings and everything is correct there. Bear also in mind that the P/L is correctly displayed if i switch and trade on SIM account. For some reason, when trade in live mode, a tick increment of 6.26 is used in calculations. I have also checked my brokers statements and the P/L and trade activity is correctly displayed there. Thanks |
[2020-07-15 11:25:03] |
Check this setting on the chart where you see that value: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Also refer to: Profit/Loss Calculations and Symbol Settings Trading Information Windows: How Average Price for Positions Is Calculated and Used Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
