Date/Time: Thu, 02 May 2024 03:03:58 +0000
round total volume values in zig zag study
View Count: 1237
[2014-01-29 19:41:35] |
User59135 - Posts: 15 |
Can anyone tell me how to round the total volume values in the zig zag study. For example in the ES, the total volume swing of say "275556" would be rounded to "275" or "276". This would be much easier to read. Thank you.
[2014-01-29 19:45:27] |
One thing you can do is go into Chart >> Chart Settings >> Advanced Settings 2 and adjust the Volume Multiplier to .001.
[2014-01-29 23:45:14] |
As an example and using the "total volume" setting for the zig zag, I get "320473" for a particular high. If I use .001 as a volume multiplier the resultant display is "0" (?) If I use a factor of .1 for the same "320473" high point, the resultant display is "219"(?) Should I not expect the resultant volume to be "320" for a multiplier of .001 for this "320473" high?
[2014-01-30 00:09:25] |
Actually as we think through this, it does make sense you are getting the results that you do. Disregard what we said. It will not accomplish what you want.
[2014-01-30 16:11:03] |
Is this something that engineering can/would add to the study or do I need to re-post my request to the community?
[2014-01-30 17:59:31] |
We do not have time ourselves for this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-30 17:59:48
