Date/Time: Sun, 19 May 2024 00:37:12 +0000
Issues installing the software
View Count: 662
[2020-07-11 21:50:35] |
A_1234 - Posts: 1 |
Hi, I keep receiving an error message while installing the software on Mac using Parallels. The error message states : "Error saving downloaded files to local system. Stopping installation.
[2020-07-12 00:37:35] |
Just use the ZIP installer instead in this case: Software Download: Sierra Chart Zip Installer Let us know if you need more help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
