Date/Time: Wed, 08 May 2024 04:26:36 +0000
[Programming Help] - Spreadsheet Stop Offset J81
View Count: 783
[2020-07-11 09:33:07] |
Tom_Tom - Posts: 40 |
Hello, i use the value in the J81 Cell for a Trailling Stop. The Value is recaculated new at every entry and most of all different to the previous entry. So at the same moment i entered a position, my value in J81 change form 0 to the new value. But this will be to late for my actual trailling stop. The stop offset in my Trade Window is not this Value, i need for my actually entry. How much time did it take to write the J81 Value to the Trade Window? Maybe i can solve this problem by another way. Thanks, Thomas |
[2020-07-11 15:38:06] |
Sawtooth - Posts: 3993 |
J81 needs to contain the offset value before an entry occurs.If the offset is unknown until after the entry, you instead could use the Trade Management by Study study, referencing a subgraph/Formula Column. Attached Orders: Study Controlled Targets and Stops Date Time Of Last Edit: 2020-07-11 15:39:04
[2020-07-11 17:29:39] |
Hi, thanks for your very nice tip! This works perfectly! But i think its time to do my studies by Visual Basic. Thanks, Thomas. |
