Date/Time: Sat, 18 May 2024 13:53:48 +0000
[Programming Help] - Opened a chartbook with Word App
View Count: 455
[2020-07-11 01:13:45] |
MT - Posts: 1 |
Hello, When I downloaded a shared chart book, I accidentally opened the files with Word App. Now all the chart book files are marked with Word sign. I was able to open all the charts in the software. I was wondering if this would cause any problem later? How can I change the files to original downloaded files? Also, is there any trial for the data service, or the free trial is only for the delayed data? Thanks. |
[2020-07-11 01:36:00] |
No this is not going to cause a problem. You should be able to right-click on a Chartbook file within the operating system file manager and select Open With and then change the Association back to Sierra Chart. What markets do you need data for or want to trade? For example, what particular futures, Forex or stock symbols. You can also give us the exchanges that the particular symbol or symbols trade on. If you require real-time futures data, then refer to: https://www.sierrachart.com/index.php?page=doc/doc_FuturesData.php Be sure to read the page linked above completely before making a further inquiry regarding real-time *futures* data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-11 01:36:16
