Date/Time: Fri, 03 May 2024 08:28:20 +0000
automated trading
View Count: 503
[2020-07-10 16:05:52] |
User166512 - Posts: 5 |
dear support i have setup a spreadsheet for system trading and i was wondering if it is possible to enter a position with attached orders only on every SECOND trade? like the system starts with +1 without attached target (take profit) and on the second +1 entry it automatically attaches a 120 ticks target to the order. is that possible? if so, how? thanks a lot for your support and have a great weekend kind regards |
[2020-07-12 23:06:30] |
This is too complicated when using the Spreadsheet System for Trading study. You need to use ACSIL instead. Refer to: Automated Trading From an Advanced Custom Study And you need to determine how to do what you want. We do not provide programming help. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
