Date/Time: Tue, 07 May 2024 01:08:46 +0000
[User Discussion] - Linear Regression End Channel Study
View Count: 952
[2020-07-10 16:05:31] |
John Mc - Posts: 32 |
Currently with the LREC indicator if you scroll back in time the LREC does not recalculate. Would it be possible to add a setting that allows you to use the End of Chart? It would use the Number of Bars setting along with the End of Chart to calculate the LREC at that was in effect at the end End of the Chart. This will allow you to analyze the chart showing what was linear regression was at a specific point in time. Hopefully this makes sense. |
[2021-01-30 09:01:08] |
Krzychu - Posts: 15 |
Im interested in this option too, was this fixed? Is it possibile to see the linear regression channel in the chart history?
[2021-01-30 10:16:54] |
Ackin - Posts: 1865 |
Do you need a historical shadow "where it was" or do you need to see a redraw when scrolling charts? |
[2021-01-30 17:25:47] |
Actually both will serve my need to see the regression channel in historical chart. Which one is possible?
[2021-01-30 17:31:42] |
this: "do you need to see a redraw when scrolling charts?" |
[2021-01-30 17:35:41] |
How to set IT up can you pls advise?
[2021-01-30 17:46:48] |
Custom Study: Linear Regression End Channel (Screen Scroll) Library Free (2020) https://www.sierrachart.com/UserControlPanel.php?page=StudyStore&SCDLLName=zyp_download_free |
[2021-01-30 17:54:25] |
The first required (track storage in history) you will achieve a "similar" effect by connecting Standard Deviation (or std Dev Bands) and Linear Regression Moving Linear Regression / Moving Average - Linear Regression Standard Deviation Bands Date Time Of Last Edit: 2021-01-30 17:54:55
