Date/Time: Fri, 03 May 2024 11:15:12 +0000
MONITOR DISPLAY
View Count: 516
[2020-07-10 11:15:22] |
User28317 - Posts: 147 |
I was wondering if you Sierra Charts can display on 6 monitors at once? I am having trouble with my setup of multi display and need to hire someone to set it up. Just want to be sure there are no technical issues with the software. |
[2020-07-10 18:31:00] |
There are no technical issues with displaying on multiple monitors. Refer to the general information here: Detaching and Attaching Chart Windows And note the section for "Alternatives to Detaching Charts" on that page. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
