Date/Time: Sun, 05 May 2024 13:23:22 +0000
Shortcut Hotkey for Order Configuration
View Count: 588
[2020-07-09 20:07:27] |
NG1980 - Posts: 39 |
Is there any way that I can assign a hotkey to switch to a SPECIFIC Saved Order Configuration? I know right now there's a way to put the order config list into focus and then manually select a saved configuration, but it would be better if I could just hit a hotkey and go straight to the config I want. If not then I would suggest a new tab in the order window where there are numbered fields where someone can select a saved order configuration, and then someone could assign a keyboard shortcut to switch to the config in one of those fields. This would be very helpful when I quickly switch to different configurations based on market conditions and scalping.
[2020-07-09 20:14:58] |
Refer to: Control Bar: Control Bar Trade Window Configuration Buttons Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
