Date/Time: Fri, 03 May 2024 19:17:43 +0000
Number bars at daily for US stock
View Count: 575
[2020-07-09 12:57:15] |
manfretto - Posts: 117 |
Hi, I have used number bars chart with volume profile for intraday @ Denali data feed. I have tried to see the same - number bars chart with volume profile for US equities @ Sierra chart data feed. I have an issue to display volume profile at daily time frame. It shows the same volume at each price level daily. For weekly is ok. See screenshot enclosed. |
Private File |
[2020-07-09 19:57:22] |
You need to use Intraday chart data always in this case. Refer to: Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
