Date/Time: Sat, 04 May 2024 06:14:34 +0000
Resolution - chart windows are tiny
View Count: 619
[2020-07-09 02:19:11] |
User627648 - Posts: 2 |
Hi, For some reason the charts are tiny within the software. I haven't been using it for few weeks and now the resolution as if it changed, it doesn't fit the window right, and there is a big void of space. The tabs of different charts are tiny that I cant read them See snapshot attached Thank you, Kareem |
sierra charts.JPG / V - Attached On 2020-07-09 02:15:48 UTC - Size: 144.87 KB - 212 views |
[2020-07-09 07:02:56] |
You need to use one of the Tile commands to rearrange the chart windows to the maximum available space: Window and CW Menus: Tile Horizontally (Window) To increase the font sizes, refer to: Graphics Settings: Adjusting Graphics Settings and Fonts for High DPI Displays Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-09 07:03:13
