Date/Time: Sun, 05 May 2024 01:06:36 +0000
Current service package does not support this function
View Count: 634
[2020-07-08 07:34:40] |
User615793 - Posts: 1 |
Hello, This morning (Paris time), my subInstance does not work and the message log shows the following message : "Connect to Data Feed | Current service package does not support this function", which is weird as my main instance works perfectly. Could you please have a look ? Thank you. |
[2020-07-08 09:02:07] |
Rexz - Posts: 20 |
I have the same problem this morining. My sub instance is not connecting to my main instance. Error: Connect to Data Feed | Current service package does not support this function. Select 'Help >> Account Control Panel' to change your package. | 2020-07-08 10:00:02.163 I know my account is fine so no idea what this issue is. |
[2020-07-08 09:24:09] |
There has been a message about updating if you are using sub instances, for at least two months. You must update to the current version: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
