Date/Time: Sun, 28 Apr 2024 17:37:44 +0000
weekly and monthly profile and candlestick charts
View Count: 825
[2020-07-08 02:47:51] |
Steve Leon - Posts: 290 |
1) Do you recommend using intraday chart setting or historical chart setting to create weekly and monthly market profiles and volume profiles ? 2) For weekly and monthly price charts do you recommend using historical or intraday charts any specific suggestions/key points to consider when choosing "timeframe setting" for the above Thank you Steven Leon |
[2020-07-08 05:17:40] |
Definitely use Intraday data for weekly profiles. And monthly if you need precision. Otherwise, historical Daily data might be ok for monthly. But probably not.
[2020-07-08 22:10:06] |
Thank you this was extremely helpful ! I have three follow up questions: 1) What do you suggest I use for intraday time settings (day-min-sec) for a TPO/VP? I was thinking day should be = 0 because its intraday. For minutes I was thinking of either using 1 min or 30 min (given market profile). So would you suggest (0-1-0) or (0-30-0) 2) Despite reading as much as I can on the support board i still dont understand the difference between historical data and intraday data ? I feel like if i really understood it i would not be asking these questions. Can you try to explain the differences and when one would be used over the other. I thought that because its a weekly TPO/VP it would use historical data. Seems like I am not understanding the difference or how to apply in different situations/different charts. 3) Which of the two types allows to obtain data further back in time ? I would think historical but i read that there is a limit of 1095 days. Is this correct ? Also for intraday chart do the number of days to load, go further back in time ? For ES (using SC data feed how far back in time are you able to go for a continuous contract (how many days to load is maximum). Thank you very much. Your time is greatly appreciated |
