Date/Time: Thu, 02 May 2024 06:24:50 +0000
How to use/interpret Market Internals NISS indicator?
View Count: 907
[2020-07-07 17:57:45] |
bootsy - Posts: 63 |
I understand that this is probably not one for Support but for other users and as such might fall outside the boundaries of what is acceptable on the Board. I understand that NISS is essentially the ADD line but can see that it is very different to ADD lines from other feeds. As such, does anyone use it regularly and if so how do you interpret it if it is different to the ADD line? Or should it be viewed in the same way wioth similar interpretations as the ADD line? A Use the NYSE tick chart which is great but am a bit non plussed by the NISS so far. It's definitely showing something, I'm just not sure what... Thanks in advance, Bootsy |
[2020-07-08 06:38:28] |
There was a problem with that calculation about a day ago: 2020-07-06 Market Statistics Based Upon Issues Up/Down But there should not have been any problem today. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
