Date/Time: Fri, 03 May 2024 03:50:27 +0000
[User Discussion] - SellExit signal is ignored. Why?
View Count: 492
[2020-07-07 14:40:27] |
ULADZIMIR VALASACH - Posts: 38 |
I plan to close the order at the moment of crossing the yellow MA-line: N3=$J$12>$AR$3. Doesn't work - why? |
[2020-07-07 14:41:58] |
File attached
ignored.png / V - Attached On 2020-07-07 14:41:50 UTC - Size: 218.13 KB - 197 views |
[2020-07-07 16:13:26] |
bradh - Posts: 854 |
I have seen this before with BitMEX. There is no open position, so the exit fails. Since Sierra thinks there is one, look for an entry in the trade activity log that is throwing off the position size. (I have seen 'Funding' in the Action Source.) You can then edit and delete the record from the downloaded data. BradH |
