Date/Time: Tue, 30 Apr 2024 06:16:53 +0000
Long Legged Doji, those are not displaying.
View Count: 780
[2020-07-07 13:32:01] |
User14953 - Posts: 188 |
Candlestick patterns finder, Harami worked Ok, but when changed to Long Legged Doji, those are not displaying. All other parameters left unchanged, but for selecting LLDoji. Restarted Sierra Chart platform, still no joy. - Wonder what I'm doing wrong? - Are the program Requirements to Qualify as LLDoji available, modifiable? CandleStick Patterns Finder |
[2020-07-08 06:08:06] |
You can look at the source code and modify it. Refer to this page: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-08 13:57:40] |
Harami display Ok using Candlestick patterns finder, but when the setting is changed to Long Legged Doji, those are not displaying. - Does Long Legged Doji display in your hands using Candlestick patterns finder? |
[2020-07-08 19:09:30] |
The rules for a Long Legged Doji are very tight and require a Doji bar to begin with. You will find the all the information for how the Long Legged Doji is calculated in the Studies4.cpp file in the /ACS_Source folder under the main Sierra Chart installation. We cannot help you anymore with this issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
