Date/Time: Mon, 06 May 2024 12:36:29 +0000
BAD data
View Count: 489
[2020-07-06 16:17:25] |
log585858 - Posts: 13 |
Hi.. I noticed recently an increase in bad data from you (SC data - All services). TODAY: 1) Bad tick in QQQ down to 245,5. Never traded there today and you did not clean it yet 1) Data is wrong in DECL-NYSE. Thus, cant draw a correct AD-line please correct asap. |
[2020-07-06 19:28:10] |
1. There is no such thing as "bad data". These are all real trades. There is no problem at all with the data. It is 100% correct. But we will review the data and remove the out of range values. 2. We are aware of this, and this is explained here: 2020-07-06 Market Statistics Based Upon Issues Up/Down Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
