Date/Time: Mon, 29 Apr 2024 21:14:19 +0000
Having technical issues with Intuitive sigma
View Count: 552
[2020-07-06 13:43:55] |
User809482 - Posts: 5 |
Hello, I am having technical issues with the system at this moment. Please, help me to fix it. Thanks |
[2020-07-06 14:57:48] |
John - SC Support - Posts: 31187 |
If you are having a problem with your Sierra Chart software, then we need to know specifically what the issue is and what has happened, or is happening.
[2020-07-06 19:38:48] |
You are referring to a custom study from an outside developer. We cannot help with this.
