Date/Time: Mon, 06 May 2024 19:46:23 +0000
Overlay Study (of a study)
View Count: 523
[2020-07-06 09:10:39] |
User441146 - Posts: 8 |
Hello, I have this setup : Current chart intraday Daily historical chart I would like to display the pivot point (W/M) of the Daily Historical Chart, into my intraday chart (the pivot points M/W of the historical chart is accurate, the one from the intraday charts are not) I can overlay the Daily Historical Study inside my intraday chart, but i can't find the way to display the studdies inside my Historical chart, into my intraday chart. Thanks |
[2020-07-06 11:36:21] |
And since i need to use two different unit of time i can't use the add additional sympbol since if i am correct it use the same unit of time, and me i want 5mn / Historical daily
[2020-07-08 09:50:06] |
Refer to this page: Pivot Points Specifically refer to this Input: Pivot Points: Reference Daily Chart For Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-08 09:50:54
