Date/Time: Mon, 06 May 2024 14:34:24 +0000
Is there a limit to the length of the formula in Spreadsheet?
View Count: 468
[2020-07-05 17:37:08] |
User804559 - Posts: 22 |
In Excel, the limit to the length of the formula is 8192 characters. Is there a similar limit for SC Spreadsheets?
[2020-07-06 00:52:02] |
No but there is a limit to the amount of characters you can enter into the formula box, which imposed by the operating system. But really we do not recommend long formulas. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
