Date/Time: Sat, 12 Jul 2025 00:53:59 +0000
ACSIL question
View Count: 1459
[2014-01-28 17:49:54] |
User40117 - Posts: 56 |
hi, making first steps in ACSIL i'm trying to create an indicator but didn't get the results i wanted, so for debugging and checking my input i tride printing values to the log. float MyFloat = (sc.BaseData[SC_CLOSE][sc.Index]); SCString Buffer; Buffer.Format("Value: %f", MyFloat); sc.AddMessageToLog(Buffer,0); This should print the CLOSE but they don't seem to match real close prices. FDAX is around +9000, the printed messages range from 50 to +1000 ??? what am i'm doing wrong here ? |
[2014-01-28 17:51:43] |
That code does look correct.
[2014-01-28 18:33:37] |
but this is the result ??? Chart: GER30 5 Min #1 | Study: Channel | Value: 22.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 38.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 44.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 29.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 29.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 33.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 25.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 28.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 31.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 34.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 48.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 38.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 33.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 35.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 56.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 63.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 41.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 29.000000 | 2014-01-28 18:31:27 Chart: GER30 5 Min #1 | Study: Channel | Value: 6.000000 | 2014-01-28 18:31:27 |
[2014-01-28 18:36:46] |
and when i just change SC_CLOSE into SC_HIGH it seems correct ??? Chart: GER30 5 Min #1 | Study: Channel | Value: 9364.000000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9363.000000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9364.000000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9355.000000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9353.000000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9337.000000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9360.500000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9365.500000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9366.500000 | 2014-01-28 18:34:55 Chart: GER30 5 Min #1 | Study: Channel | Value: 9363.500000 | 2014-01-28 18:34:55 |
[2014-01-28 19:45:24] |
vegasfoster - Posts: 444 |
This may be not be the cause of your problem, but I've had problems before as well using SC_CLOSE in basedatain so I use SC_LAST and that seems to always work ok.
[2014-01-28 20:19:18] |
Thx, will try it
[2014-01-28 21:23:16] |
Not sure unless we were to test this with the exact same study function. We see no reason why there would be a problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-28 21:23:26
[2014-01-28 21:24:25] |
We did not catch on to this earlier, but SC_CLOSE is not valid. That is some other value defined by the Windows operating system. You need to use SC_LAST.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-28 21:24:36
