Date/Time: Thu, 02 May 2024 10:38:26 +0000
SC ChartTradeMode - Graphics on top left
View Count: 559
[2020-07-03 17:27:57] |
ejtrader - Posts: 688 |
SC Team - I am trying with a default install and customize only part that is needed from default. I couldn't figure out what option wouldn't hide the settings on top left side of the chart when ChartTrade Mode is enabled. Tried different graphics settings but was of no help. Could you please let me know which option to use so that the text is visible or allow me to change the color from light blue to something else so that the text is visible. thanks |
SC_ChartTradeMode_graphics.JPG / V - Attached On 2020-07-03 17:27:46 UTC - Size: 17.47 KB - 215 views |
[2020-07-04 08:29:06] |
The text in that area is using the general Text Color. Refer to this setting: Graphics Settings: Chart Text Since it appears that you want the rest of the text in your chart to be that color, then the best option is to change the background coloring for that area. Refer to the setting here and the one after it: Customizing Fonts, Colors, Line Styles, and Widths for Chart Trading, Chart DOM, and Trade DOM: Chart Trade Mode Box Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
