Date/Time: Mon, 29 Apr 2024 23:08:06 +0000
Duplicate Bid/Ask Top-of-Book values Chart DOM
View Count: 541
[2020-07-03 16:17:49] |
User24791 - Posts: 44 |
Greetings, Chart DOM is displaying duplicate Top-of-Book Bid/Ask values...How do I remove them so only one displays? Thank you...David http://www.sierrachart.com/image.php?Image=1593779936884.png http://www.sierrachart.com/image.php?Image=1593793410794.png Date Time Of Last Edit: 2020-07-03 16:25:46
[2020-07-03 17:18:11] |
You have the following setting turned on, turn it off if you do not want to see the additional number: Global Trade Settings Windows: Display DOM Depth Totals (Global Settings >> Chart DOM Settings >> Other>> Other Settings) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
