Date/Time: Tue, 07 May 2024 03:27:45 +0000
OpenGL GPU Usage & Performance
View Count: 1244
[2020-07-03 08:45:13] |
samual sprat - Posts: 343 |
Hi, I remember pre SC version 2090's that the GPU usage under opengl was much better than it is now. Not sure when this changed but my charts currently use 90-95% of GPU and the same charts used to hover between 10-35%. Despite the increase in GPU usage, the performance of sierra doesn't seem to have improved Is opengl still work in progress in terms of GPU optimisation and performance? Thanks S |
[2020-07-03 09:10:50] |
All development related OpenGL is complete. You need a faster GPU. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-03 09:13:14] |
lol
