Date/Time: Tue, 07 May 2024 00:08:14 +0000
Atas XV Range Chart
View Count: 2319
[2020-07-03 07:20:26] |
Timo Costa - Posts: 28 |
Hallo ich möchte gerne wissen ob Sierra in der Lage ist oder wäre einen range chart zu erstellen so wie bei Atas der XV range chart ? Dieser chart nimmt oder minimiert das Markt rauschen. Vielen Dank |
[2020-07-07 10:02:25] |
Yes, you can create a Range Chart. Refer to the information starting here: Chart Settings: Intraday Chart Bar Period >> Bar Period Type >> Range Per Bar - Standard (in ticks) (Chart >> Chart Settings menu) Be sure to review the information further down, as there are multiple Range Bar types that can be selected. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-07-08 11:20:27] |
https://cdn.discordapp.com/attachments/665613123339681805/730380567488626828/4range-xv.png Ich hoffe das bild ist zu sehen. Also Atas nennt es Range chart aber der balken hat keine genauen vorgaben. Er verändert sich . Gibt es irgendeine lösung bei Sierra chart die das selbe kann? Vielen Dank |
[2020-07-08 19:06:24] |
From Google Translate: I hope you can see the picture.
So Atas calls it a range chart, but the bar has no precise specifications. It changes. Is there any Sierra chart solution that can do the same? There are too many charting options for us to possibly know what that chart is. You would have to go through the options and see what would match up based on the settings for that chart versus what is available in Sierra Chart. Be sure you also look at the Renko charts, as it is possible that it is one of those kind. Refer to the information for the various Bar Period Types here: Chart Settings: Time Period Per Bar / Amount of Data Per Bar (Chart >> Chart Settings >> Bar Period menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-08 19:06:45
[2020-07-13 10:16:24] |
Vielen Dank. Das mit dem Renko Chart ist eine sehr gute Lösung.
[2020-07-14 08:49:08] |
That is good.
