Date/Time: Tue, 30 Apr 2024 22:04:12 +0000
Sierra Chart Data Feed vs. Denali Data Feed
View Count: 632
[2020-07-02 20:22:10] |
User643426 - Posts: 93 |
Regarding the question and response listed below posted earlier, would you recommend getting the Sierra Chart Data Feed and not the Denali Exchange Data feed if I want to use it with the two brokers and so I don't have to run two installations of Sierra Chart? If I do choose the Sierra Chart Data Feed, I would purchase it through Sierra Chart and not AMP so I can also use it with Interactive Brokers correct? Thank you. I would like to activate the Denali Exchange Data Feed through my Sierra Chart account to access full CME group Market Depth data for non-professionals for $31.20/month and use the data through both my Interactive Brokers and AMP brokerage accounts. Would it be possible do that so I don't have to pay additional fees for the data through each my two brokers? You will need to have two installations of Sierra Chart, one for use with AMP and one for use with Interactive Brokers. As long as both installations are on the same computer, then you just only need to pay for the data feed and exchange fees once and you will be able to get the data into both instances/installations. Refer to: Using Multiple Data and Trading Services at the Same Time |
[2020-07-03 15:45:23] |
No, you are getting things confused. If you want to get data for the CME Group, then you must use the Denali Exchange Data Feed. In terms of connecting to two different brokers, you really need to do that through two different installations of Sierra Chart. Therefore, this does not have anything to do with the choice of data feed, it is simply the way you need to setup given the information you have given us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
