Date/Time: Fri, 03 May 2024 07:44:23 +0000
Denali Exchange Data Feed
View Count: 526
[2020-07-02 15:21:01] |
User643426 - Posts: 93 |
I would like to activate the Denali Exchange Data Feed through my Sierra Chart account to access full CME group Market Depth data for non-professionals for $31.20/month and use the data through both my Interactive Brokers and AMP brokerage accounts. Would it be possible do that so I don't have to pay additional fees for the data through each my two brokers?
[2020-07-02 17:44:29] |
You will need to have two installations of Sierra Chart, one for use with AMP and one for use with Interactive Brokers. As long as both installations are on the same computer, then you just only need to pay for the data feed and exchange fees once and you will be able to get the data into both instances/installations. Refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-07-02 18:09:59
